The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
My PC tun on then immediately turn off
My PC is just boot looping, like it starts automatically when I give power then it just stars for 1 second (like fan and all run) and then every thing stops then again stars for 1 sec and every thing stops. But when it like actually run fully it stay on and no problem but right now it's just not starting, help me ma guyss much needed all my work is hanging.
Same problem
My initial guess would be, there is something drawing too much current since the processor never seems to get to even try to boot the system.
Start by unplugging and/or disconnecting anything you can, one at a time. Like hard drives, removing ram, etx.
If you find nothing, remove the processor to see if it stays on. If so, it could be the processor or it may still be a MB problem.
Now you need to decide what you want to try to replace first.
I will try it
In my experience, the most common cause of boot looping is faulty RAM. Remove the ram sticks one by one. Try with a single stick in the first slot and see if things improve.
Did you manage to solve this problem? I have the same one after disassembling, cleaning and reassembling...?
omsolanki crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,112
