Guides and repair information for washing machines produced by Samsung Electronics, a South Korean engineering and technology company.
No hot water WW80M645OPX/EU samsung qdrive washing machine
Samsung
washing machine has no hot water. I have tested thermistor it appears fine. ohms resistance drops with hand heat. element is fine 2.2 ohms but when on washing cycle no hot water is created ive attached crocerdial clips to power input on element no voltage detected on terminal on heat part of cycle . I have replaced pcb board b dc92 02140a note no error coded shown on machine. I am out of ideas
in the end it was the wiring loom i had to strip down to locate and bridge broken wires.movement between drum and loom. I hope it helps others
@philippric92934 and that is the way to fix things :-) Great job and just in time to finish the weekend laundry!
I have the same symptoms - heating element and thermistor resistances seem normal. When I disconnect the thermistor the machine runs exactly the same (no heating) and the connector on the yellow/orange wires is showing open loop (although not sure what the resistance would be on that side). How did you fix your wires?
Have you checked the filter element in the hot water hose?
If it is not that, then it is likely a bad water valve. There are 2. One for hot and one for cold.
Uk machines use a single cold feed in the end it was a wiring loom issue. after stripping down the loom part of the thermistor circuit in the loom had snapped causing open circuit
Philip Price crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 239
