Start button is not doing anything
The belt is on correctly, and the manual reset did not help. The start button does nothing; almost as if there’s no power.
This is the best site for turntables I have been able to find:
Turntables, Tonearms and Cartidges
Appreciate it! It looks like it might be a bad motor, so I'm probably in a position to replace, but I'll bookmark the site.
Cheers
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
You may need a multimeter to check if the motor itself is dead. If it is the motor, the replacement may be available via Audio-Technica directly. The part is weirdly hard to find online otherwise. you can contact them via email at parts@atus.com. (If in the USA, check your regional Audio-Technica site for a parts page otherwise.) It will, however require a bit of soldering to replace as two of its wires are connected to another board directly instead of via a push connector.
You can see details as to how to do this in this guide for its predecessor: Audio Technica AT-LP60BK Motor Replacement
The internals are the exact same between the LP-60 and the 60X layout-wise. AFAIK the only major changes were in the physical appearance of the turntable. I would not recommend de-soldering while the motor is still in the unit (as in that old guide) as the entire shell is plastic. It's also just a big unit, which you already know due to owning one. It'd be annoying to work on it like that.
Does it indeed make a mechanical "click" when start is pressed?
Jeremy R. Stoll crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 83
crwdns2959996:0crwdne2959996:0 5,660
