screen locked on a iPod nano 5th generation
I went to the screen lock and clicked it and put in a combination and now I can't get out. HELP!!!!
Tammy, here is what I found out "According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data." There is more on here Hope this helps, good luck.
I also have an iPod nano 5th generation and also forgot my password, but the problem is I don’t have a computer, is there another way to do it?
@amaya23 sorry but there is not. You will need a computer
I fixed my problem but is there a way to restore all my stuff
crwdns2942667:0crwdne2942667:0 10,585
crwdns2944067:04crwdne2944067:0
How do I solve a combination
crwdns2934271:0crwdnd2934271:0 Daniel Reeves crwdne2934271:0
How do I factory reset my Apple nano 5th generation
Daniel Reeves, You should be able to factory reset the Nano by holding the Menu button on the click wheel and the centre (select) button together. Hold for ca. 10 seconds
crwdns2934271:0crwdnd2934271:0 Geir Ove Andersen crwdne2934271:0
I have a combination lock on my apple nano 5 generation it says lock screen on it how do I unlock it do you have any suggestions
