A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
pc artifacting, not sure what to do
hi everyone, i am a first time pc builder and i have had my pc for a couple of months now. everything has been running smoothly until i recently started getting gpu artifacts all over my screen. im not sure how to fix this and i dont wanna cause any damage to my internal components
Update (07/11/23)
just thought id add my specs
gpu- rtx 3090ti msi suprim x
cpu- intel i12900k
motherboard- ASUS Intel Z690 ROG STRIX Z690-E
Update (07/25/23)
@oldturkey03 @jayeff i have updated my drivers and after doing that ive had no issues
crwdns2944067:05crwdne2944067:0
@callumventer " gpu artifacts all over my screen" what do those look like? Try to be decriptive or post a picture of those with your question Adding images to an existing question
while playing games in fullscreen i have not seen any artifacting, but when on my desktop using apps like my browser, i sometimes see groups of small black squares all over my screen appearing for no more than a second or two before disappearing and reappearing somewhere else
@callumventer this "see groups of small black squares all over my screen" is usually a memory issue. It is possible that your games are a bit to emory intensive. I agree with @jayeff, let start by getting the newest drivers for your complete system.
@callumventer so updating the drivers worked?
@oldturkey03 seems so
@callumventer
How much ram is installed in the desktop?
Have you got the latest rtx 3090ti msi suprim x driver version 536.40 installed?
Did you mean a ROG STRIX Z690-E GAMING WIFI motherboard?
If so have you got the latest Version 2306.4.3.0 chipset drivers installed?
currently ive got 32 gb of ddr5 ram
i honestly dont think i do have the latest drivers. where can i get those
@callumventer
I linked the drivers in my comment above your last one. Click on the blue links
I'm curious if you have enough power for that card. You didn't mention your power supply, but Games can get pretty demanding at higher resolutions, (and even for a split second) can cause artifacting. I could also be a result of overclocking, or card overheating.
If you have a friend, etc. who has a similar system, consider swapping a different GPU or PSU.
i have a 1000w psu and unfortunately i do not have any friends with a pc
that should be adequate. When you are in-game are you seeing the squares, or only on the desktop?
only on the desktop
hi everyone, i have done some in game testing and it seems temperature cannot be the issue, my gpu sits around 45-50 degrees while gaming.
Callum Venter crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 184
