This page exists to help you troubleshoot, maintain, and understand your MSI GE76 Raider (Intel Core 11th Gen, GeForce RTX 30 Series), first released in 2021. Models include 11UH, 11UG, and 11UE, with each model having sub-models.
meu pc apos mudanca pasta termica nao arranca
mudei a massa termica do pc removendo a bateria e desde enetao nao foncionou mais. o que podera ser?
Google translate:
my pc after changing thermal paste does not start
I changed the thermal mass of the pc by removing the battery and since then it has not worked anymore. what could it be?
@filipemoutinho since it worked before and stopped working after you changed the thermal paste, make sure that everything is properly connected. Double check each and every connector. Make sure that they are properly seated. Use a multimeter and measure to see if your computer gets power from the DC in Jack.
Translation
@filipemoutinho uma vez que funcionava antes e deixou de funcionar depois de mudares a pasta térmica, certifica-te de que tudo está corretamente ligado. Verifique novamente cada um dos conectores. Certifique-se de que estão corretamente encaixados. Usa um multímetro e mede se o teu computador recebe energia do conetor DC in.
Filipe Moutinho crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 248
