Kettle won’t heat, base is fine
Hello,
Fellow has sent me thru the normal rigamorole with descaling, and when that didn’t work, sending a replacement base. The kettle is the problem, and now they are offering to replace the kettle. But I want mine to work, I don’t want to throw another unrecyclable piece of trash into the landfills.
Does anyone know how to start investigating what’s wrong with it, or anyone else who has successfully repaired a Fellow Kettle?
Thank you!
crwdns2944067:07crwdne2944067:0
@valentine89505 can you post some good pictures of the base and the bottom of the kettle.? Let's see how this all comes together. Do you have a multimeter and some basic hand tools, like screwdrivers etc?
Adding images to an existing question
Have you opened up the kettle? I know there's a fuse or maybe a diode that can go bad. Looking at how this is working may solve your issue.
I have one of these that stopped heating. I tested the thermal fuse and it was good (it has continuity), and the heating element measures about 12 ohms so it is also good. The contacts on the kettle and the base are all clean and bright. So i assume the control in the base is bad even though it powers up and shows the "Fellow" logo and then lets me set the temperature.
I have the same issue - the base turns on, correctly senses the water temp, but does not heat up. How do I isolate the base versus the kettle as the failure? I have a multimeter.
Thanks for your assistance.
Follow up: for some reason i got the idea that the little peg in the bottom of the kettle was not working, causing the control in the base to not turn on the current to the heating element. Fellow unhelpfully tells their customers to "descale" the appliance--after it stops working when it is impossible to boil vinegar or whatever they recommend you go buy for "descaling." So i took a wirebrush with a small amount of acetone and carefully cleaned that little peg in the bottom of the kettle. Then i cleaned the kettle with soap and water, and after that it worked fine. I suspect anybody could achieve the same thing with a wet toothbrush and a bit of baking soda. I don't know why the company can't just say to try that.
crwdns2934275:02crwdne2934275:0
Based on what you're describing and what I was able to gather online, it sounds like your heating element has failed and you will need to replace the thermal fuse.
If you decide to attempt this repair yourself I strongly encourage you to document your repair so fellow (get it) Fellow Stagg EKG owners can benefit in the future. Learn how to create a guide on iFixit here.
I created some general guidance on what you can do below.
Safety First! Before you begin, remember that safety is paramount. Always disconnect your kettle from the power source before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your device.
  1. Remove the screws. At the bottom of the base should be 3 triangle head screws, 2 3mm and 1 2mm. You can find the bit in your iFixit Pro Tech Toolkit, or feel free to buy one here and here.
    1. You can also use a Torx T7 and Torx T8 bit if you have those handy.
  2. Open the base. The bottom should open up easily once you've removed the screws, but you may need to pry it open using an opening tool (also found in the iFixit Pro Tech Toolkit). Prop it against something sturdy or hold it open with your wrist using your less-dominant hand. You'll need your other hand to turn more screws in the next step.
    1. Be careful! There is a blue wire that connects the base to the rest of the device, on the side where the spout is.
  3. Access the fuse. In the base, on the end nearest the handle, you'll find a white-sheath with a red wire coming out of it going into what looks like a wire nut. Beneath this wire is a small Phillips screw you need to remove in order to access the fuse. Once the screw is removed, you can remove the sheath around the fuse coming from the red wire.
    1. You may need to use tweezers to remove the screw as a magnetized driver doesn't always pick it up.
  4. Replace the fuse. The fuse is made by Microtemp, and the model number is G4a00 184C. G4 line is for 10A 250v which is 15A 120v. Aupo brand (Aupo BF184 10A) is another option.
    1. Use Crimp Connectors to remove the old fuse and attach the new one.
    2. If you don't have Crimp Connectors, you can use electrical tape to hold the new fuse together temporarily.
      1. Note that this is not a good option long-term and you should properly connect the new fuse with Crimp Connectors.
crwdns2886500:0Pliers for crimping tiny JST, Tyco, and Molex connectors.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Micro Connector Crimper
$44.99
crwdns2886500:0The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.crwdne2886500:0
Pro Tech Toolkit
$59.96
crwdns2886500:0Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.crwdne2886500:0
iFixit Opening Tool
crwdns2886500:0iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit.crwdne2886500:0
iFixit Precision 4 mm Screwdriver Bit
$2.99
I too am having the same problem. I tested the continuity of the thermal fuse in the kettle base with my multimeter and registered no change from the baseline reading. Should I still try to replacing the fuse? If it is not the fuse, where do you think I should be looking next to figure out what the problem is?
I had the same issue - correctly reading the temperature but not heating. I’ve replaced the fuse and it’s made no difference. Unfortunately I don’t have a multimeter so I can’t be sure.
Anyone else had this issue after replacing the fuse?
did you crimp or solder? If you soldered the fuse in you may have blown it as It is a thermal fuse.
Hi @ciaranoflynn
Don't know the kettle but I'd try testing the kettle element and temp sensor? with the Ohmmeter.
Looking at the base for the kettle there seems to be only 3 connections that connect to the kettle.
Presumably an active lead, a return and a temp sensor? lead.
Measure between all three connections on the kettle i.e. inner conductor to 1st ring, and then 1st ring to 2nd ring (and even inner conductor to 2nd ring) and check what you get.
Also check between all leads and the metal? body of the kettle
Usually elements are between 20-50 Ohms but the temp sensors are more but they shouldn't be open circuit.
If the kettle appears to be OK then the problem is in the base
Valentine crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 390
crwdns2942667:0crwdne2942667:0 8,187
