Wireless Connecting Device Wi-Fi capable of connecting multiple devices.
[Linksys E5600] Need to set wifi channel manually after restart
My router is E5600, not E1200. After a restart, I need to login to the router page and select and unselect the wifi channel to 'Auto'. Otherwise, it merely shows up on all devices but I can't connect to the wifi from any of the devices. I'm able to access internet via LAN, so that makes it clear the issue is with the Wi-Fi. Can anyone tell me a possible solution to this problem? I can't keep having to login and change the channel manually after a restart
I use Linksys Wi-Fi extenders and they were quirky. I have to ask the obvious question - have you updated the firmware? I was ready to junk them at first.
https://www.linksys.com/cn/support-artic...
https://openwrt.org/toh/linksys/e5600
Normally when I’m having issues with a router the first thing I’ll do is perform a hard reset of the router. This can be accomplished by making sure the router is connect to power and is on then inserting the end of a paper clip into the reset hole and holding the reset button down for 20-30 seconds. Once the router has been reset, you will have to reconfigure it. Make sure that during the reconfiguration process you update it’s firmware to the latest version.
Hope this helps!
Tavezzzzo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 245
