Where can I buy battery
Can I buy a battery for it
Logitech doesn't make the UE Hyperboom very serviceable. I believe the battery part number you're looking for is 533-000170, however, this is not available for purchase from what I can tell.
You may be able to take the battery out and replace the actual individual cells but this is a dangerous repair. If you're interested in looking into that type of repair you can ask for guidance on Reddit from qualified experts.
But do you know what order do the batteries go?
Unfortunately, I do not.
ifixit.com has the battery for sale Logitech UE Hyperboom Battery
Do you know where I can buy a new charging mother board for the hyperboom I need the battery too but pointless to buy with out the charging board
@joseperez82998 you are the one that has the battery, so you can help us to help you. All you have to do is carefully cut the white wrapper and remove it. You'll find things like this
wrapped up in there. You can replace those with 18650 and a bit of spot-welding. Like my esteemed colleague @cvneutron already said, "ask for guidance on Reddit" and they are the ones that have tore the battery down. Use that as your guide.
Here is what appears to be the BCM and again, it's really is not as complicated for as long as you use common sense and proper tools.
For the 18650, the positive side is the one that has the groove on it. Of course, always verify this with a multi-meter.
Here is a decent video about the [https://www.youtube.com/watch?v=v8RfULoV... |battery replacement]. The following images will shed some light inside the Hyperboom.
While you work on your Hyperboom and the battery, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Hi can anyone confirm ... output of the battery ..probing Red and black wire should be Voltage ?... as Im getting no voltage .. .. however Black wire to these joints est TV1 4v TV2 8v TV3 12v TV4 16v TV0 is Earth = Black Wire. is this a BMS problem if know how to wake it up ? also what are the White Blue n Yellow wires for ? cheers
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 1,417
