AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Replacing Magsafe "T" connector with an "L" connector
Hi,
I have a Magsafe 85W with a broken T connector, and I have a Magsafe 85W with an L connector but a failing power supply.
So I want to replace the broken T connector with my other L connector.
It would be ok to join both cables in the same order, the inner cable of the T power supply, with the inner cable from the L connector, and the outside cable with the outside cable from the L connector?
Thank you!
Esteban
Sure. I interchange them all the time.
Thank you for answering, it's working perfect.
Like the previous answer. Connect the inner cables together and the outer cables together. I just did it and it works perfectly.
There's supposed to be a "fix" that simply is a small adapter thats plugs both tips together so you don't have to buy (or fix switching cables) a completely whole new charger when all you need is the T tip to be an L tip. Anyone know how to even find it? I did once before but I didn't save it, and Applestore doesnt know what im talking about. Supposedly Apple knew of this "tip" change from the T tip to the L tip on their chargers, and made a simple small adapter to plug both tips into for connection. IN other words, if you had the T tip charger, but you need the L tip charger, you dont have to buy the WHOLE CHARGER, just use this small tip connector adapter.
Esteban Eid crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 9,159
