Why is my scooter running when turned on
When the power button is pushed the scooter starts running without using the throttle
Disconnect the throttle then turn it on. If it doesn't try and move then the throttle is faulty.
Thank u I'll try that when I get home but wat if it still moves ?
@cheriebelt then the control box has failed and needs replaced. You could also check for shorted components inside the box or possible damage to the throttle or cable itself if its been dropped or accident you will need a multimeter.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 127
