The Bose Soundlink Revolve Plus is a portable Bluetooth speaker that was released by the Bose Corporation in 2017.
Does anyone have any experience removing the battery?
The battery is soldered on by 2 different set of pins, and I have been trying to remove it but have not been successful. I have tried doing a couple of tips and tricks I found online about removing through put connectors, but the problem with the battery in this case is that is you really can't remove one set of pins at a time, and im not sure heating up the entire area is a good idea as the battery is directly behind the logic board.
Have you seen this one? Looks easy enough, no?
https://www.youtube.com/watch?v=9npIN_un...
Sort of, the pin design is a bit different on my battery pack. Mine's doesn't have one of the pin sets loop up and over the logiv board, both sets are through hole pins. It doesn't help that I'm still a novice with a solder kit, maybe I just need to be a bit more aggressive with it.
For context, here is the battery that my speaker has
https://www.amazon.com/gp/product/B0BPY6...
But I will definitely give this recommendation a try! Thanks for posting this, this is the closest video I've seen to my speaker that specifically deals with the battery replacement. Wish me luck!
@luis Rodriguez Have you been successful?
Luis Rodriguez crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 2,838
