A bluetooth Marathon Mouse by Logitech released in 2010.
Fix Left click button
Left click don't work while all other buttons work properly
Imad, when you press the left click button, does it still make a sound? If not, you probably either need to replace the switch (the mechanism that registers clicks) or buy a new mouse (if you don't want to disassemble your mouse), and if so, it's probably something a bit more complex, in which case I would heavily recommend buying a new mouse.
Dear Shingle
Thank you for your quick reply.
Yes i still have a click sound ;what to do in this case?
@imadchidiac Well, that means that the switch isn't broken. What specifically are you using the mouse for? Also, how long have you been using it for?
I used for a smart TV less than a year
Hmm. And all the other mouse buttons work? That's quite strange. Have you tried using a different mouse? If left-clicking doesn't work with the different mouse, then it is a problem with your smart TV. If left-clicking does work with a different mouse, then you should probably just buy a new mouse. Personally, I would recommend the Logitech K400 Plus if you want a trackpad-keyboard combo, or either the Logitech M705 or M330 if you already have a keyboard (the M705 has better battery life, but is slightly more expesnsive, and both mice are on sale).
I have this issue and am willing to explore other options. The device is out of warranty, so I have nothing to lose. If it still makes a click sound, what are some things to investigate other than replacing the switch?
Maybe worth a try--what do you have to lose?
(I'd use electronic cleaner or 91/99% alcohol instead of WD40):
https://www.youtube.com/watch?v=-w-W6MAn...
Good luck!
Imad Chidiac crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 2,827
