LCD screen Ribbon Connector
Hi,
So i have a random question. I had a broken samsung tab 3 and iv taken it apart for a project. I wanted to know is there a way to change the Ribbon Connector to a 40pin? Or is there away of taking the gray tap (not sure whats its called) to put a 40pin ribben cable to it and complete void the LCD board.
Update (06/23/23)
Hi sorry about that.
Im wating to reuse it for a rasberry pi by installing a Display Monitor Driver Board
@learning201 the board we are looking at is the LCD driver board? Connected to your display panel? What is the exact model number for your tablet (GT-P5200?)
By using the display connector schematic, could you not determine which pin does what and move on from there.
if you add photos and the reason why you want to change to 40 pin then it will give people a better understanding of what you are trying to do
Update 06/23/23
@learning201 you would need to find out what each pin is for, some will be ground, others could be for single rails or you could have 2-3 pins connected to 1 rail
Learning201 crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 404
