Charge battery a last time outside?
It started with a small puff of smoke. The laptop kept charging, but video output didn’t work anymore. Then one day suddenly the laptop didn’t take charge and eventually the batteries went out before I had backed up all the data. Now I want to recharge the battery one more time to get all the data out of the solid-state hard drive. What is the best way to do that without spare logic board or computer?
I already swapped out the USB-C connector and the separate logic board.
@bjoerns55432 there really isn't a good way to charge it. Your battery is a smart battery, so it does communicate its state of charge to the computers charging circuitry and in a back-and-forth decision is made to charge or stop charging etc.
Granted, I (but this is me and I do not advise anyone to do this or try this) would probably go ahead and connect my bench power supply and connect positive and negative correctly and apply a trickle charge to see if that will charge the battery. It will depend on and the battery controller to accept this as charge or it may not even know I am applying a charge. Of course, I would do this under controlled circumstances and not leave it unattended, monitor heat etc. while doing so. Again. This is me.
For you, I suggest you find somebody that has the same setup as you and ask them to charge my battery in their computer. Otherwise, you'll have to fix your logic board first.
Björn S crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 108
