Hot water keeps flowing when the power is ON
Hi, I have a Samsung washer WF45T6000AW that keeps filling with hot water when the power is ON. For example: I run a cycle and the hot water will keep flowing. When I pause the cycle, the hot water still keeps flowing. When I turn off the washer from console the water still keeps flowing. Only when I unplug the washer from the socket is when the hot water stops. Please note that the issue is only with HOT water and not cold. I am able to using the washer normally on cold cycles.
I suspected that the hot water inlet valve was an issue - so I replaced it with a aftermarket part which didn't work so I thought I need the OEM. I installed the OEM but the issue is not resolved. Seems like some other issue.
Your help and inputs would be highly appreciated.
