Asus zenbook WHEA error when pluged in
Hello, i have problem with one asus zenbook, i dont know now the exact model number but is i7 8gen with integrated HD graphic 620. When the laptop running from battery is all ok, when i plug the charger (type c power delivery) after cca 5-15min come blue screen with WHEA error. When i disable the hd graphic erron not come. Its the cpu KO?
If you see WHEA_UNCORRECTABLE_ERROR, it indicates a hardware error. You probably need to reinstall or fresh install Windows 10. In most cases, system reinstallation will cause data loss. Thus, you are advised to recover data from your computer even it fails to boot.
I allready reinstall windows, try install on 2 different SSD. Everythink working Fine till when is hd graphic driver installed and plugged to charger. Any idea?
VojTech crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 112
