Hi @mj470,
What is the model number of the refrigerator?
Try placing a sheet of paper between the door and the door jamb and then with the door closed normally try pulling it out. By normally I mean no pressure on door so that it is fully shut. Just close it as you normally would
It will come out with a bit of an effort, but not easily and it definitely shouldn't fall out by itself.
Do this at various places around the door, top, bottom and both sides.
If it comes out too easily or falls out, check that the door seals are OK e.g. not loose, broken, twisted etc and also that the door is aligned parallel top and bottom, to the cabinet as it may be a hinge adjustment problem
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
