Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
Flickering horizontal lines on retina MB 2017
I've got a MacBook 2017 with flickering horizontal lines which make it almost unusable. My suspicion is that it could be the LDVS cable.
Anybody else seen this problem and tried a fix ?
You could try disconnecting and reconnecting the display and perform an NVRAM reset, but on this model this symptom most likely indicates a failing display assembly. The issue might be due to a failure of the attached display board, but in either case you'll probably need to replace the display to fix it. Good luck!
Hook it up to an external display to verify your diagnostics.
Alastair Nisbet crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 93
