Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
The speaker sounds like under the water and very low
I've bought a used iPhone XS and I noticed that it has some problems with the speaker. When someone is calling or when I am listening to something with maxed out volume the sound is very low and non clear. I also noticed that when I typed, the sound was low and for a second went loud and back (again).
At the end should I replace the loud speaker?
Which speaker? Ear speaker or loud speaker? Clean both anyway. The mesh grill on the ear speaker gets clogged with dead skin and grease whilst using the phone. A tooth brush and a LITTLE bit of isopropyl alcohol and some patience should do it. Also clean the microphone and speaker holes at the bottom of the phone the same way. Use a little alcohol as if you use too much it could leak into the top of the screen.
So basically I tested this phone through some YT videos and through a call. I found out that both speakers have a very low quality and volume. What should I do?
(Both the screen and back are broken if that helps!!)
Sotiris Konstantopoulos crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 186
