Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 973
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
When I turn it on, it starts in the middle of the mixing cycle.
crwdns2934271:0crwdnd2934271:0 Janet Schuroll crwdne2934271:0
