Jura brewing weak coffee
Hi,
My Jura Ena Micro 90 has started brewing very weak coffee. Regardless of the set grind and coffee intensity (usually finest grind and maximum strength) my coffee has started getting thinner and thinner. I've played around with settings but nevertheless the brew is turning out watery.
I've noticed that the ground coffee in the waste basked is quite dry, although I get the normal amount of liquid in the cup. Could there be a leak somewhere that prevents the water from properly going through the coffee?
The machine is about 5 years old, I clean it regularly with original cleaning tablets and I use the Claris Blue filters. I've been using the same brand and type of coffee beans since new, but lately have tried other coffee brands (both beans and ground coffee) with same poor results.
Unfortunately the local Jura service has quoted an absurd price for the repair without a guarantee that it would be a permanent fix...
