Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
Why does my phone charge for long
Phone charging system
crwdns2889612:0crwdne2889612:0 11
Charging is very late
Why my phone décharge kwikly?
=== Update (02/02/25) ===
Pourquoi mon téléphone s décharge vite?
@habib2927 @akshayshri55686 this can have many different reasons. First start by making sure that your charger supplies the proper voltage. Next check the charging cable. Make sure that there are no bend. broken. or corroded pins. Now focus on the charging port. A few drops of high-grade isopropyl alcohol and a few puffs of compressed air will clean out the port.
If all of this does not work, then it might be time to disassemble your phone. Think about replacing the battery as well as the USB charging port. Anything after that, will require some board level repair. For that you need to have the tools, the schematics and the experience to repair that.
Well I will suggest you to replace the battery of your mobile phone and keep cleaning the junk files from your phone and remove the unwanted apps which run in the background.
Iwant to fix it
Had the same issue before—turned out my charging port was full of dust and lint. I used a toothpick to carefully clean it out (gently, so I didn’t damage the pins), and suddenly my phone was charging normally again. If you’ve had your phone in your pocket a lot, dirt can build up and block the connection.
Charge system problem
Habib crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 1,833
