The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
Truck won’t stay running
So I have a 2001 dodge ram 2500 5.9 gas 2wd. The problem I’m having is the truck will start and run good sometimes and sometimes it just dies as soon as you start it, it also always throw a p1296 and a p0505. I have changed fuel pump, pick up coil, cap and rotor, spark plugs and wires, and all of the sensors on the throttle body (map, iac,throttle position sensor) and also have replaced evap canister. I need help
p1296 Dodge Manifold absolute pressure (MAP) sensor no 5 volt supply
Same issue with p0505
Juan Guerrero crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 134
