How to replace external volume button, which fell off?
volume slider fell off, looking to replace it by myself
Hello!
I know this is an ancient post, but the button fell off my P7Pro as well, and since this pops up in google I thought I'd leave a few notes.
If you look closely at the button, you'll notice that one of the inner sides has a blue-ish tab, and the other one doesn't. This tab helps keep the button in place in the device, but it seems that the factory glue is not durable enough. The missing tab is most probably still in your phone in the volume button slot, and you'll probably need a needle or very thin pliers to pick it out. Be careful as it's super tiny.
Now when you look at that tab closely you will notice that it has a flat side and a beveled side. The flat side is the one that should be glued to the volume button. If you have a friend that is into building/painting miniatures, this would be a good time to ask them to glue it back, as they are probably more used to handle such tiny parts and have better equipment. Otherwise, read on.
In order to glue it back correctly, I used some modeller glue(Revell contacta) because it's slower to dry and the needle-like part makes it easier to apply just enough glue. Any similar glue should do, and I'll advise against using instant glue as it dries too fast and the residue is harder to remove if you don't make it the first time. The volume button also has a couple of standouts to guide the tab in the correct place, so it shouldn't be too hard to glue it. Just add a tiny amount behind those, make sure the flat side of the tab is facing the glue, and push it in. Let it dry for a few minutes, and then you can try sliding it back in the phone by fitting first one side and then carefully pushing the other downwards and inwards.
Good luck.
If the external volume button on your device has fallen off and needs replacement, here are some general steps to guide you:
I got buttons from AliExpress. Quality is decent. Finally my phone is as good as new.
I also ordered buttons from AliExpress hoping that the product was legit. I was pleasantly surprised when I received the order. Not only was the product an exact match to the original it came with the teeny tiny rubber piece that keeps the button from falling off. I popped it in and boom I was back in action. I'm going to reorder a couple of backups because I'm sure eventually the button will become loose come out. Also wanted to mention that not only was the product exactly what I was hoping for but the price was $3.36 total... that's all. Other vendors on the website(AliExpress) had them for anywhere from $7-$20 and I decided to go with the cheapest and I'm glad l did. Don't get me wrong the other pricing is still better than I thought it would be. I imagined replacement buttons being 50 bucks or something which would have been a freaking joke. Anyway I am very happy and sorry I rambled on 😄
Super Bro, can you share the same link
ordered mine from here, but looks like only gold left in stock
Yes Indeed, I bought severe sets on amazon thinking it would happen again.
They do not have the same bulky appearence AliExp shows. I use a buffer case which secures them on the P7-Pro from 2022. Now in 2026 for some reason I took off the case to clean it and the buttons disappeared. Lucky me I had the replacements ready to go buffer case back onphone works just fine. I don't remember paying ~ $9-11/set. May ~$3-4 before tarriffs ? Sounds like the Pixel 10 Pro has the same problem.
I saw some pixel pro 7 volume buttons on AliExpress website. They're really cheap or inexpensive I should say. I had the volume button fall off on mine and it's so frustrating! I also read a review that mentioned the little tiny rubber piece that goes with it which is good to know. I'm hoping it's still stuck in the phone. I'm hesitant to order from any third party vendor but I don't know how long I can go without a volume button. Thanks to Google for the design flaw on an $900 phone. Frigging ridiculous. Here are a couple more places to try:DHGate and SaleHoo
Goodluck!
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 110
crwdns2936753:030crwdne2936753:0 507
crwdns2959996:0crwdne2959996:0 19,473
Is it not under warranty? If it is get it done under warranty. Save you voiding it incase of future issues.
crwdns2957956:0crwdnd2957956:0 [deleted] crwdne2957956:0
Bro did you get genuine part of it ?
crwdns2957956:0crwdnd2957956:0 Aditya Chintapalli crwdne2957956:0
I need help to fix my gp7p because my bottom fell out any suggestions also I can’t find my button
crwdns2957956:0crwdnd2957956:0 Miley crwdne2957956:0
