screen case seal heat pressure advice
i'm talking about the pre-cut frame seals on the blue plastic, however, if there is advice that can be equally applied to tesa tape, it's welcome too.
i've read that after the screen is mated to the case it's advisable to use heat, or pressure or both to help the adhesive set.
for heat, there are heat guns, microwaveable bean/rice bags, heat tables, etc.
for pressure, there's heavy books, wood/C clamps or phone specific edge clamps.
my question is what is your recommendation for using heat and/or pressure to make the adhesive set better?
i don't have a heat table, but i do have a heat gun and a laser/infrared thermometer so i can't really dial in a temperature, but i can heat the phone and read surface temperatures. most heating advice is "until it's just too hot to touch" and i'd like something more quantifiable than that.
what temperature to you heat the phone to?
once heated, how long do you apply weight/pressure to the seal?
Thanks
