The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
crwdns2934591:0224crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone fell down and does not switch on, even connected to PC
iPhone fell down from 1 meter height flat on ceramic floor and switched off. Glass is not broken. It does not switch on, and when connected to PC - there are no signs on the screen. What is the possible failed part and if there is anything I can try to fix myself? Thanks in advance.
crwdns2889612:0crwdne2889612:0 8
crwdns2942205:01crwdne2942205:0
I had the same problem..no reaction whatsoever after it had fallen out of my pocket. . I had the akku /charger/ battery...I am not sure about the correct term for it- replaced and everything worked nicely again. It cost 35€ at a professional store.
Try this, but you will lose all files etc that you have not backed up. If you are using the same computer it will restore from back up.
1) plug your phone to your computer while running iTunes.
2) perform hard reset by holding home and sleep as you've done before
3) wait for phone to reset Apple logo will go off and come back on... do not release buttons!
4) keep holding until the phone resets one more time and displays the recovery mode screen
5) follow the instruction for 1) restoring from backup or 2) setup as a new iphone
If that will not resolve your problens, it may be time to take it apart and have a look at the obvious parts that could have failed. Unless you have it apart, anything will only be a guess. Start with the battery if you must. Hope this helps, good luck.
Hi iphone 6plus fell, the LCD got broken but still in tact then suddenly the phone became very hot. Now it wont turn on or reflect in the computer. Is there still hope? please help
Thanks man! I had the exact same problem, and thought it is plain dead, but after your instructions it works like a charm, you might saved my iphone :).
My iphone fell down from my chest to the ground and now it doesnt turn on, if i connect it to charge, it turns on and resets infinitly, what i can do to fix that?
crwdns2942205:01crwdne2942205:0:
you already solved it?
My iphone fell down from my chair to the ground and now it doesnt turn on, if i connect it to charge, it turns on and resets infinitly, what i can do to fix that?
Update (06/21/2018)
My phone fall today morning 13/9/20. It was not opening. Then immediately gone to a local shop they fixed for $15.
Photo Fraiman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 31,029
