How do I fix my horn?
The horn doesn't honk
Hello @sandidelreal ,
As @jayeff pointed out. The most common and easiest thing to check are the fuses and the relay. Fuses first. As the Relay you cannot see if the connection is broken. Here are some other things to check also.
1. Horn itself. They very rarely break. Yet can happen. Use a Volt Meter to check if there is power when the horn is depressed.
Thank you lots, to you as well.
Check that fuse #63 and relay R3 in the engine compartment #2 fuse block are both OK.
Here's a video that may help.
Thank you for the small help.
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 2,005
