The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
How to repair my touch screen?
Hi there,
First of all I would like to thank you for your time. I recently picked up a switch that I am trying to repair. The switch leaked over a year ago. I have already dismantled it and cleaned the oxidation marks with alcohol and a toothbrush. Currently it works as a home console, i.e. I can use it with a wired controller but there are several problems:
-the touch screen doesn't work
-The joycon charge when I put them on the rails but they are not recognised by the console, I can only connect them as external controllers while they are charging on the console...
-I'm not able to turn the console back on when it's in standby mode, so every time I want to use it I have to press the power button for a long time to turn it off completely and then turn it back on again
Everything else is working fine
Do you guys have any idea or advices about my failures ?
Thank you !
the joycon rails probably got damaged and need replaced as for the touch issue it could either be the digitiser or the game cartridge reader at fault
Eliott Guira crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 49
