Repair and disassembly information for HP 15 Laptop PCs, specifically 15-ef models. The HP 15-ef is a budget laptop series featuring 15.6-inch touchscreen displays, AMD processors, DDR4 memory, and solid-state storage. Identified by model numbers starting with 15-ef.
Color changes on screen
A few days ago, I boot my PC and I realized the screen has changed from it normal color to a pinkish color . I want to know how to get rid of it
My first suspect would be the video cable. If you can (with it powered off), disconnect & reconnect the cable and then try rebooting the laptop.
The ribbon cable (usually located on the back side of the LCD). Sometimes just reconnecting it will do the trick. If not I would suggest to replace the cable before any other parts (it should be relatively inexpensive.)
The connectors are fairly fragile, so be gentle with it or watch a YouTube video on LCD replacement for your model (i'd skip to the relevant parts)
La pantalla de mi pc se pixeleo y se coloco con un tono rosa, ya trate de reiniciarla, hasta la apague y deje descansar pero sigue igual.
Si le tomo una captura se pantalla o algo por el estilo se visualiza normal.
Ari Know crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 480
