Fixing my worktunes question, thanks!
I have a few pairs of worktunes that have stopped working. (I kept buying new ones instead of trying to fix them) One of them I opened up and pushed the battery plug back into place and it started working again but the other two still aren't working after that particular fix, and it doesn't look like any of the wires have come loose from their solder connections. Do you think buying a new battery and swapping it out with fix them?
They are 100% unresponsive, no blue light when charging, nothing happens when I hold the on button.
Thanks for any insight!
The problem I have is the headset will come on and play and then suddenly stops working after 5-10 minutes. The blue light is still on and I still get voice when I switch between AM, FM, Bluetooth. It’s as it when the circuits get warm they just cut off the broadcast stations. I did turn it to Bluetooth and it played but at a volume I could barely hear.
Any ideas about what’s happening?
I for one used mine in a place where the button would get dirty and gummy, so if that's the case for you the button might be stuck, or, the charge port itself could be gummed up. Otherwise, I'll bet you could test the battery, and see if they have any power at all.
Zayd Zaytoon crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 1,037
