Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Bottom screen glitching when I change the brightness?
On the bottom screen of my 3ds looks like a bit of the left side of the screen is being shown on the right side instead, and it flickers between doing that and being normal. If I change the brightness it usually stops glitching, but it still shows some of the left side of the screen on the right. Also it just started showing vertical black lines that flicker on the bottom screen if I have the screen on a low brightness, but this only happens occasionally. I bought the 3ds pre owned so I have no idea if it was dropped or water damaged before I got it but in the month I've had it I have not dropped it or spilled water on it.
Any information on what might be wrong with it would be appreciated :3
It looks like the display is damaged. It could be the connection or the screen itself. You'll probably have to replace it.
Nintendo 3DS Lower LCD
Hope this helps :)
crwdns2886500:0Replace the LCD located in the lower half of the Nintendo 3DS.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$24.99
goofy goober crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 286
