The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why it takes long to charge my phone
I have been charging for 10 hours now still not full. Why?
crwdns2889612:0crwdne2889612:0 11
Slow change 5 hours full change
Mobile is too slowly charge
Wy the background not work and the screen is so slow
If your phone is taking a significantly long time to charge, there could be several reasons for this:
  1. Charging Cable and Adapter: Ensure you are using a high-quality charging cable and a compatible charging adapter. Faulty or low-quality cables and adapters can result in slower charging speeds.
  2. Battery Health: Over time, smartphone batteries can degrade, leading to longer charging times. If your phone's battery health is low, it may take longer to charge fully.
  3. Background Apps and Usage: If you are actively using your phone or running power-intensive apps while charging, it can slow down the charging process. Closing unnecessary apps and reducing usage can help speed up charging.
  4. Charging Port and Connection: Check the charging port on your phone for any debris or damage. A dirty or damaged port can affect charging efficiency. Ensure a secure and proper connection between the cable and the port.
  5. Charging Method: Using a slow charging method, such as a computer USB port or a low-power adapter, will result in slower charging speeds compared to using a fast charger.
If the issue persists despite trying the above steps, it is recommended to contact your device manufacturer or visit a service center to diagnose any potential hardware-related problems with your phone's battery or charging circuitry.
Fast changing
Fast changing
nimaga internet ishlamayapti
Dee crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,398
