Why my phone vibration is not working
My phone vabrtion is not working correctly
Hi well this video might be helpful for you: https://www.youtube.com/watch?v=W0-_BKzz...
Why Samsung Galaxy M32 Vibration is not working If you are experiencing issues with the vibration not working on your Samsung Galaxy M32, there could be a number of causes. Here are some possible reasons why your phone's vibration is not working:
  1. Vibration is turned off: The first thing to check is whether the vibration is turned on in your phone's settings. To do this, go to Settings > Sounds and Vibration > Vibration Intensity and make sure the switch is turned on.
  2. Phone is in silent mode: If your phone is in silent mode, it will not vibrate. Check the volume settings on your phone to make sure it is not in silent mode.
  3. Vibration motor is damaged: If the vibration motor in your phone is damaged or malfunctioning, it may need to be repaired or replaced.
  4. Software issue: Occasionally, a software issue can cause problems with the vibration on your phone. Try restarting your phone or performing a factory reset to see if this resolves the issue.
Source Finddee
Why my phone not vibrating
#0# dial this number and then select vibration in the menu
mintesnot ayele crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 137
crwdns2942667:0crwdne2942667:0 18,670
