Samsung's tenth-generation flagship "phablet," with S Pen stylus and 5G capability. Released August 2019.
Overheating Error Glitch with Note 10
It is not actually over heating rather I assume bad sensor somewhere. I have successfully pulled the back off the device but cannot pin point the faulty hardware. Some help would be appreciated, thanks in advance
Hi there! This could either be a faulty charging port or a faulty wireless charging coil as both have built-in thermal sensors! It's very unlikely, but if neither of these fix it then it may be a logic board issue. Hope this helps @beefman26 !
Sorry I didn’t get a notification of your answer. It also doesn’t charge wirelessly. I just tried a new charging coil with no luck. Is there anything else I can try? Thanks
@beefman26 Could be the charging port, if i remember correctly there's a thermal sensor on there too! If not, a battery might be another good shot
Ethan Lewis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 549
