The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disc will stop spinning
My discs will initially start and load up, I can play for a few minutes. Then the disc will stop spinning during game play. I’ve tried cleaning the lens to no avail. Curious if this sounds like a fixable issue? Has happened with multiple games.
Rather than typing them all out again, this thread has a number of potential solutions to the issue you are having, hope this helps!
Disc not spinning in GameCube
This is a very common problem with all disc drives, the disc motor bearings get a tiny bit tight and it doesn't rotate at sufficient speed to recognise the disc, trying adding a tiny, very tiny! bit of oil to the disc motor bearing and see if it works
M Doe crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 723
