Instead of using the heat mat, can I use a heat gun...
Instead of using the heat mat, can I use a heat gun to take off the screen to get to the battery?
Yes you can. Apply heat around the edges then insert your opening tool freeing a bit of adhesive at a time. Then repeat until the screens off. Using some isopropyl alcohol as well will make the job a lot easier.
Do I need to use plastic picks? or can I use a spudger?
@nytryder26 I’d use a thin opening tool to make an opening then a thin piece of plastic. Plastic picks or a spudger might be too thick cracking the screen.
@strongbow Like this kit? iOpener
@strongbow Ok Ill check it out!
crwdns2942667:0crwdne2942667:0 69
