Wont power on at all after battery change
I was using the laptop one day and then it just suddenly shut off and would not come back on. I changed the battery and it still will not power on. Need some help on what the problem could be.
Hi @walla52779,
Does the laptop indicate that the battery is charging when the charger is connected?
No. There is no charging light indicator when plugged in
Hi Walla. I have come across a similar issue with 2 Lenovo Ideapads in the last 2 weeks. Remove the installed ram stick and the laptop should turn on. It is either the ram that has gone bad or the ram slot itself. With the 2 laptops that i dealt with, one was the ram slot that had gone bad and the other the black metal shield that was screwed over the ram. When i removed this shield the laptop powered up fine.
Walla crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 392
