Repair guides and support for motorcycles manufactured by Harley-Davidson.
My speedometer light works intermittently
On my 2009 stock dyna streetbob the backing light for the speedometer goes out at cruising rpm. When I let off the throttle and go back to idle rpm the light comes back on. This happens consistently. All other lights, the speedometer, odometer and clock are all working correctly.
I believe it turned out to be the stator
Have seen a couple different things cause this issue;
1. Bad voltage regulator
2. Wires under rear fender getting worn away by the tire and creating a short
3. Loose battery terminal connection
4. Speedometer might be going out
I'd start with the easy stuff like checking the wires tightening the battery connections/making sure the terminals aren't super corroded and go from there.
Hope this helps!
Thank you Robert H. I'll start there👍
Have exactly the same issue. Did you fix it?
I believe it turned out to be the stator. I replaced it
Jesse Duncalfe crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 275
