A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
My screen fell and became black, what should I do?
I have Samsung galaxy tab a 10.1 (2019)
The screen glue that kept screen with it was weakened somehow and screen was coming out multiple times but since it was not a big deal as everything seems to work perfectly I ignored it.. Until today My screen came out and fell on my table ( u can assume position of tab like distance to be like 20cm touched with the surface with angle of 80° approx.)
I don't know how much damage it did internally but what I can observe was the ribbon/ flex cable or whatever you call that cable came out of screen
I panicked and tried to put that back and black screen of pixels which glow a bit white on ends showed indicating that the screen was working
I repeated the same process by unplugging and re-plugging the cable again and again then suddenly I noticed drastic heat or overheating in cord and when connected to screen, In screen as well, I was panicked again and removed it again and repeated same process after sometime...
Note that there is no physical sign of broken ribbon or screen
and now I can see nothing is working either plugged or unplugged But i can hear sound by checking by my Bluetooth speaker indicating that its on
Also Bcz of some reason I cannot go to a repair shop or buy some new replacement for it
Can you please help me in fixing it myself at home???
@helpme97578 going by your description, this sounds typical for a broken screen (internally not on the outside). You will have to replace it. Samsung Galaxy Tab A (2019) Screen Replacement
Help_Me crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 433
