Hi @secondradrracc
The LCD panel is cracked and cannot be repaired. It needs to be replaced.
Here's the maintenance and service guide for the laptop.
Go to p.37 to view the procedure to remove/replace the display assembly, if the display is a touch screen and continue on if it is a non touch screen so that the LCD panel can be removed
Depending on whether your model has a non touch or touch display, go to p.14 to find the part numbers for the non touch LCD panel (Item #2) and p.12 for the touch display assembly (Item #1).
Search online using the part number only to find suppliers that suit you best.
If yours is a non touch model, usually the part number can be found somewhere on the back of the LCD panel if you wish to verify that you're getting the same one.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
