Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
power button stopped working after back glass replacement
I was replacing my iPhone 12 Pro Max back glass and when I went to go turn the phone on the power button wasn’t working. If i tap on the screen it turns on but if press the power button nothing happens.
This is a super common issue following back glass replacement on most iPhone models.There is typically a small gap in the chassis where the flex cables lives. It's all too easy to accidentally nick it when removing the old back glass. The little arm of the cable that handles the power button is extremely narrow. So it doesn't take much.
Hi Samarjit,
Yeah, that's the problem with back glass replacements - you end up exposing the phone's internal components to the high heat needed to get the glass off. In addition, since the wireless charging coil is exposed, it's susceptible to a random piece of glass or a slip of the prying tool.
On the iPhone 12 Pro Max, the power button is integrated with the volume buttons, the ring/silent switch and the wireless charging coil. Chances are very good either the heat or a tool damaged that assembly, resulting in a non-functional power button. Here's the part you need.
iPhone 12 Pro Max Audio Control Cable and Wireless Charging Antenna
Unfortunately I haven't been able to find any guides to replacing that part. The best I can suggest is to watch some teardown videos and use what existing iFixit guides there are to take out the components as they're encountered in the videos. Here are a couple to get you started.
iPhone 12 Pro Max Teardown - iFixit
iPhone 12 Pro Max Teardown - YouTube
Since you're blazing new trails here, it would be awesome if you could take pictures along the way and create a guide for others who end up with the same problem.
crwdns2886500:0Replace the internal audio and power switches with their brackets and the wireless charging antenna compatible with the iPhone 12 Pro Max model A2342, A2410, A2411, A2412.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$18.99
when I am replacing the power button it only clicks towards the middle. When I click toward the bottom of the button nothing clicks. Do you know what I can do to fix this issue? I have been trying for hours now
@samarjitdebnath I would take a look at the physical button itself and make sure it's undamaged and correctly mounted. There's an iPhone X guide to those buttons that will help with taking it out and reinserting it.
iPhone X Power and Audio Exterior Buttons Replacement
Start at Step 72 and be sure to check out iPhoneRepairGirl's video.
https://www.youtube.com/watch?v=hwlKlzsJ...
Samarjit debnath crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 3,806
