The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Why does my washer leak during fill
I changed out the water fill valve. All connections are tight no leaking. Now my washer leaks at fill what could cause that?
@annsanders can you verify for us that your washer is a MVWB765FW? Also, do you know where it leaks from, like the bottom, or the back or other places. Since you replaced the water inlet valves already, I would suggest to look somewhere near the drain pump.
When you reinstalled the inlet hose to the fill valve are you sure the rubber seal was in the end of the hose.
Ann Sanders crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 128
