L2-R2 / LT-RT potentiometers.
(This question is about the nacon wired ps4 controller)
Hello, im currently repairing my old controllers. Everything is going well but i am struggling to find the right parts for the nacon wired ps4 controller. It may confuse you that the subject contains xbox triggers but i believe that the wired controller has the same build as the xbox controller. However.. the potentiometer (button/switches on the pcb) i have on the nacon ps4 wired controller are hard to find. The ones i do find are for the xbox controller BUT... The shape were the L2-R2 stick/shaft is mounted in has a + figure. The xbox version has a half cirkel. I noticed that the numbers on the L2-R2 potentiometer contain a L or a R ( B1-03-2L-30 and B1-03-2R-30). Im a bit struggling to find the right parts. Does anyone know what the right name or number of these components are? I hope my question is clear and you guys can help me. These are literally the last parts i need to complete my "project".
Thanks and have a good day!
Update : this seems to be a though one. I ordered the components for the xbox controller. When they arrive i will mount them on the pcb and keep you updated.
Wich companies make these components? I could ask them. Thanks again.
crwdns2944067:07crwdne2944067:0:
@wiilsj can you add some images to your QUESTION so we can see exactly what you are referring to?
Adding images to an existing question
@oldturkey03 i Added the pictures.
@wiilsj let's see what we can find out.
@oldturkey03 thanks alot. I found these on ali : https://a.aliexpress.com/_mN49WTa
These are most similar but are made for the xbox controller. I did order these for a try out. Im confident i can find a way to instal the (+ shaped) shaft into the half circle shaped attachment point. it would be better to find the right components. Thanks for your reply
@wiilsj I agree. I bet you could make it work but we want to make sure that we at least try to find the right parts.
Repair is War on Entropy!
crwdns2934275:02crwdne2934275:0
