The HTC Desire is the first smartphone of the Desire series developed by HTC.
White lines on a black screen and no damage to phone?
Desire screen just stopped working. Can only get a black screen with white lines. Taken battery out , put back in --same. Is my lcd gone ????
Phone looks like brand new.
But what if your battery don't come out
yes what if my battery does not come out
I found out that due to the usage of the phone the foam pad in the back of the LCD flex cable tends to shrink a little and the battery's weight tends to push the flex cable out of the main board socket. I added some clear tape by rolling it up to make it thick, and stick on back sides, and place it on top of that foam pad.
crwdns2933315:06crwdne2933315:0
could be. http://www.formymobile.co.uk/desiredisas... will help you to get to the screen to check connection or replace
This might be more use:
http://androidforums.com/desire-support-...
I solved this problem few times by completely opening my HTC Desire Z mobile phone and then reassembling it. Third time, I noticed that the problem is due to looseness of two, out of three, tiny screws at the "camera" button of the mobile set. Therefore, mobile set was not properly pressed and sealed at the "Camera" button and due to some protection by HTC, screen went black. Now I have used new relatively long tiny screws and the problem is solved permanently.
i had this problem to but mine was becus of preassure damage!
Are you having your phone in your back pocket?
Heat can damage the screen and cause pixels to malfunction
Display bord‌‌‌>chack capacitor> hot air
Doug crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 22,326
