Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
Laptop not turning on
Strix g15 ryzen 7 4800h and GTX 1650 ti
The laptop is not turning on , the power indicator does not light up even if charging . The laptop flashes the power light for a brief second at the moment the power is connected and goes dim again ...
Sometime i just let it sit for 4-6 hrs and it generally starts to work again , the laptop is currently not turning on
I have tried unpluging the laptop and holding the power button for a minute or two , and when i connect the charger and try to start it the power light just flashes and the laptop does not turn on .. please help
I have also tried the hard reset when the battery is removed ...
I have look at the forum for any possibile solution .. i have also replaced the motherboard but the same problem persists ...
Any suggestion pls
did you check your work on the motherboard? you may have left connectors off of the board or ripped them
I have also the same problem, if your problem get fixed plz can you help me
Try a different charger o r charger cable
Rashid crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 815
