Tv suddenly turned black screen.
Tv suddenly turned black screen. It has power on LED on, back black light on screen, and i can hear voice when i press the button on remote. But than that nothing work.
@rahulmahid31488 explain this "back black light" a bit better, First you need to verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a channel where you can hear the sound. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue. Also, verify that your TV is a 32H4C
crwdns2934073:0crwdne2934073:0
@lauramurengwa is this an answer or a question? No signal? Plugged the cable in?
Are saying you have some issues with some TV?
Same but no sounds
If your TV suddenly displays a black screen, check the power connection, ensure the input source is correctly selected, and inspect cables for damage. Try restarting the TV or updating its firmware. If the issue persists, it could indicate a hardware problem, and professional assistance might be required.
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 3,066
