A LED bulb 230V is a type of light bulb that uses Light Emitting Diodes (LEDs) as a source of illumination and is designed to operate at a voltage of 230 volts. This type of bulb is commonly used in areas with higher voltage electrical systems, such as in Europe and other parts of the world that use 220-240V AC power.
Switching on the bulb
My washroom's bulb always blinks several times before comes to proper working condition. So what is the reason behind this?
Hi @muhammedsa33137,
Please verify the type of bulb e.g. Incandescent, CFL (compact fluorescent), Fluorescent tube or LED.
It is an LED bulb.
My bulb is not working what i do?
@muhammedsa33137 take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adding images to an existing question
crwdns2886500:0iFixitcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937585:0crwdne2937585:0
2 - 5 minutes
crwdns2886500:0LED Birne 230V LEDcrwdne2886500:0
LED-bulb 230V E27 repair
crwdns2937801:0crwdne2937801:0
30 minutes
crwdns2886500:0LED Birne 230Vcrwdne2886500:0
crwdns2947821:0crwdne2947821:0
Hi @muhammedsa33137
It may be that the electronic components in the LED light are beginning to fail. Usually it is the capacitors in the light as they may fail prematurely due to the heat generated by the operation of the LED light.
It could also be that the light is loose in the light fitting, making for a poor electrical connection
Muhammed Saad Islahi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 597
