The Anbernic RG353V is a handheld gaming console designed for retro gaming enthusiasts. . The device features an IPS display that delivers vibrant colors and wide viewing angles, enhancing gameplay and overall enjoyment.
Does not turn on
Just bought it. Played about a 30min then charged it to 100%. Then played again for a while, around 15 minutes. After that console did hang. Tried to reset it, but it does not turn on at all for now...
Faulty Power Adapter
  1. Check to see that both the adapter and the cord are undamaged.
  2. If the cord is plugged in and the Anbernic shows a bright yellow light, the Anbernic is charging. Try to turn it on after 10 - 20 seconds.
  3. If the yellow light doesn’t show, consider getting a new cord. (Make sure that the cord is the correct type.)
  4. If getting a new cord fails then it might mean that the battery no longer works and you will need to buy a replacement battery.
Stuck Button
  • There might have been debris or dust that got stuck into the button.
  • If you fail to find dust or debris then get a screw driver and unscrew the Anbernic to try and manually fix the button that is stuck.
  • If you find debris or dust, you will have to find a soft and dry object that you can use to clean the button to help it get unstuck.(usually an old toothbrush should do the trick.)
Nyo Nor crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 417
