Repair and additional information for the Kenmore Refrigerator 795.7430*, a bottom-mounted freezer refrigerator with French door access and automatic ice maker, introduced in 2018. This page covers information for model numbers matching the pattern 795.7430*.
kenmore elite 795-74305-810...what pressures should this r134a run
working on a kenmore elite 795-74305-810 134a unit how many amps should the compressor draw and what pressures should it run in a 70 degree room ??
I am a commercial refrigeration tech...but am not familiar with residential units like this...I repaired a leak but have trouble weighing in 4oz...plus i changed the drier and believe that will change the charge any way
The r134a needs to be weighed with scales. These are linear compressors and exact weight is a must. It’s difficult to charge them going by the PSI. If it has 2 evaporators you’ll need to put the 3 way valve in neutral before pulling the charge and leave it in neutral to recharge.
I l am aware that I’m answering this 2 years too late, I’m known for never being in timer. Maybe someone will need this info one day and here it will be.
Brian crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 134
